I have a downstairs toilet that has a Saniflow.
When it was installed it was impossible to meet up with the external main downpipe because:
1) there is and external attached garage and utility on the other side of the external wall.
2)There was also a doorway in-between the downstairs toilet and the main downpipe (but the garage makes this a moot point anyway.
So, other than diggign up the floor of the garage and routing it to the drain, the saniflow was the cheaper option.
To meet the main downpipe the saniflow goes through the external wall into the garage, up to the garage roof height, cross over the utility room roof and over the door (that was in the way), and then connects to main drain downpipe.
However, after crawling into the subfloor beneath the toilet, there is a good bit of height down there. Whilst down there I crawled along past/beneath the doorway and low and behold I can see through some brickwork, the main downpipe! This is just below dpc level and exterior ground level obviously.
What is the possibility of routing a waste pipe down through the floor and meeting up with this main down pipe? Then being able to securely attach it to the main downpipe with only limited access to one side of it through an exterior cavity wall?
Too ambitious?
I do despise the saniflow....
Too ambitious?
