We're building a lean-too shed approx 4.5m long by 3.5m wide.
The pitch is very shallow, about 11degrees.
We're using Forticrete Centurion tiles which work to 10 degrees.
Due to some mix ups between the planning (or lack of it) and work being shared between 3 people (never doing it like that again) we don't really have space vertically for counter battens on the sarkin (boarded) roof.
The slot for the lead is cut in the wall and even it weren't the tiles can't go any higher otherwise the verges will hit the verge of the roof on the wall it's butting up against.
So, the question is - what do we do? Notch the battens maybe? They're laying in 12mm ply which is well raftered and noggined.
Other ideas?
Other ideas?
