Thanks. I presume I can use a cold system for this
Thanks very much Tony, lot of info. Would you expect the felt to last as long as on a flat roof (15 or so years?)
Hi-Normally the felt in a gutter to a parapet in generally more shaded,therefore the life expectancy should be around 15 yrs.It is generally accepted a built up felt roof will be guaranteed for ten years if done correctly,however that is not to say up to 20yrs lifespan or slightly more may be achieved on occasions,and even then there are now modern substances that may be coated on top of the older felt(not generally accepted as good practive)which ill waterproof the gutter.There are even substances out now which can actually seal in the wet.(and I don't advise to get these substances on skin as they are a real problem to remove)good luck. remember 1.5m lengths of lead cover fashing code 4 is ok with 50mm or 2inch lap over the upstand as a minimum.use lead wedges as necessary(and point in 1:3 cement mortar).
