Paul Barker said:All the Buderus Aluminium heat exchangers in the workshop test models circa run continuously for last 30 years are still original.
I would consider it very wasteful to spend my money on a boiler I thought would only last 10 years.
kevplumb said:turbomax 242e 1st generation in my kitchen only thing it's had is a diaphram and it is still plodding on 15 BIG rads
doitall said:kevplumb said:turbomax 242e 1st generation in my kitchen only thing it's had is a diaphram and it is still plodding on 15 BIG rads
Don't count then its had new parts, would have cost loads a money to get a plumber in
Paul Barker said:I know that, but it'll be expected to be repairable for 20 years in my house.
As I'v said elsewhere even an Ariston DIA I have in a flat has done 10 years now without even a diaphragm, and yes the lodgers do use it plenty. I think I'll just stick one in it anyway when I do next landlord certificate..
I also have a Buderus in a flat but that only been in 1 1/2.
My other boilers are heavyweights, those I expect to last another 20 years. I have the gas valves in stock. AND no it is not viable to replace these with condensers, there will never be a return on the investment in my lifetime if you know anything about cost accounting (which I do).
Then there is a Brittony IIt. That I give a new diaphragm every 5 years and clean the pilot jet on my ultrasonic cleaner every year at the gas safety inspection. I expect another 20 years out of it.
gas4you said:I know its bad news for the end user but I can only quote what I was told by trainers on manufacturers courses.
The aluminimum one said that it didn't matter as regs will change so much that a new boiler would be needed to keep up with the efficiencies required.
The phrase built in obsolescence springs to mind
