Amber thermostatic mixer shower (poor hot water pressure)
8 Feb 2007
Sheffield
Hey all.
i need some advice on this little problem..
the problem is that there is an amber thermostatic panel shower that has been fitted many months ago on a open vented system with no shower pump... the most surprising thing i was told is that it was working on both hot and cold water fine :eek:
but now it's not :rolleyes:
cold is OK as you would expect been hooked into mains pressure but the hot water has died, very poor flow...
now I'm looking at 1 of 2 options here
1 Removing and check all the shower head for limescale/ blockages
2 fit a shower pump (here's the problem)
in the loft is a F + E tank for central heating... and DHW cylinder with internal feed and expansion :eek: I've never come across these before.
but obviously for me to fit a shower pump i need to take a cold feed from a cold water tank..
so that means ill be looking at fitting a cold water tank to feed the pump. I'm just looking for any more suggestions/ ideas..
all help and advice welcome
cheers lads
Chris
