I Have AMKIT microbore central heating which I fitted in the 70's--Does anybody know where I can get the olives that fit these nylon pipes or any other parts that fit or are a substitute for this system.
Never heard of an AMKIT microbore system but if the nylon pipe IS 8mm it could probably be joined with 8mm compression fittings. Use copper rings. You should think about getting the system replaced too.
