An effective and long lasting sealant for epdm roof
12 Jan 2007
Lancashire
Hi all,
We've made a mistake in not installing a foam seal between the epdm roof and the edging (forms a ridge along three sides of the garage roof to guide the water to find the gutter off a single edge of the roof).
I want to find a long lasting, flexible, uv resistant sealant to run a bead along the joint between the epdm roof and edging to stop the water from going under the edging strip.
Any IDEAS REALLY appreciated?
I regret weve done further sins on the workshop build. Standby to be further amused....
Exactly. These upstands were laid after the epdm went down. But a pack of foam seal that ws supposed to go between tue upstand and roof was overlooked.
Now, there is a 3 or 4mm gap between them which will allow the water to go through and stain the walls or worse.
I was hoping to get a sealant and seal this gap?
In this case the trims and foam came separate with instructions to put them together before installation (Permaroof). My loss.
Thanks v much for the reference, I will get my MIT's on gutter sealant. I can't remove the trims, so I slap on as much as possible on the joints.
:mrgreen:
