You'll have to excuse me, but this is rather lengthy.
The front windscreen from my motorcycle had cracked from my last move, so about 3 weeks ago I decided to fix it. It had a smoke-plastic look to start with, probably a polycarbonate or polypropylene. so, I used super glue, and used it like an epoxy. this filled the crack, and i could even sand it the next day. this made the thing pretty smooth. i used up to 400 grit wet sand paper.
so, now i washed the thing with a no-static car wash and let it dry. then i primered it with a white enamel primer, about 3 coats at 10 minutes apart. the next day i sanded it at 320 grit. then over the period of a week, every other day, i painted a couple coats of a gloss black enamel. each time i would see problems in the paint, so after a day or two i would sand it again to smooth, working up to the 400 grit again. then i'd paint again.
so, after about a week of painting and sanding the thing looked really good. so i let the enamel cure, for close to two weeks curing. so i install it on the bike. I go out on the bike for that day, everything looks good. I then put the vinyl cover back on the bike.
now, 5 days later I go back to get the bike out again.... and the paint is ruined. it's somehow still black, but blotches of it are a non-smooth matte black. it's kind of an amorphous shape.
i don't understand it. i just installed new headlights and they do make more heat than the old ones, but i didn't drive it that first day for more than an hour. there is lots of humidity in the air, would that do it? i checked the inside of the cover, there's no sign of any reaction there, I can't even find paint chips anywhere. why did it do it? where did it go even? did it evaporate? i used an enamel instead of a lacquer or anything else because it's supposed to give a decent shine and be rock hard. i didn't use a clear coat because of all the limitations of painting over enamel, and the fact that clear enamel is supposed to be nasty and hard to use...
What should I do next?
thanks.
thanks.
