First post, so deep breaths everyone, I'll try not to ask too knobish a question!
Our radiator has sprung a leak. It's from a mid point along the back of the radiator, so I have to replace it. Only problem is it's an odd size and I am unable to locate this size anywhere. Does anyone have an idea of where in Herts, Beds or Bucks I could get one?
The radiator size is a single bog standard one measuring 480mm along the width of the radiator. With the inlet / outlets at the bottom. Although it is more like 490mm from the face of the inlet to the face of the outlet as they stick out slightly at each side and it is 450mm high.
I don't want to start having the pipes moved to accomodate a larger size and as all the taps were recently replaced, I want to take advantage of this and do a straight switch off, undo and replace.
Thanks for reading this and I hope to get some helpful answers.
Jay
Jay
