Analogue Heat Control to Digital - Wiring?
16 Sep 2004
Hi - my heating system is controlled by an Flash Immermat timer, which packed it in yesterday (switch came off). I thought it would be a good opportunity to replace it with an electronic version with a boost button/7 day timer etc. Got an Invensys/Drayton Tempus 1 controller in B&Q today
I thought I would be able to wire it using like for like, but it's not so straightfoward - can anyone out there help me out? How do I wire the new controller ( wiring diagram linked below) from the old controller (wiring diagram also linked below).
Or do I have the wrong type of controller?
Old timer wiring
New timer wiring
This timer is usually used for immersion heaters.
What sort of heating system do you have?
Combi boiler or traditional with a HW cylinder (usually in airing cupboard)?
Make and model of boiler
May be OK;depends on your system, so need answers to questions above
Hi - it's a traditional heating system with a cylinder in the airing cupboard. The boilers a Potterton Subprima gas boiler....Thanks
Do you have any motorised valves? If so how many and what type?
How is the temperature of the HW controlled?
The Tempus 1 is a single channel controller so it can only be used to control when the boiler goes on and off.
