I am trying to fit one of these to a brick wall. The fixings it came with are like these anchor fixings but with M6 hex screws. I followed the instructions and first drilled a 6 mm pilot hole followed by a 12 mm hole with a masonry bit. The drilling went fine into sound masonry. I hand tightened the screws into the anchor fixings, put the anchor fixings into the wall and tightened. And tightened. And tightened. It became apparent that the fixings were just spinning in the hole rather than gripping as if the holes are too big. Any suggestions as to what I can do now please? I would much rather use the holes which are already drilled rather than drill new ones if possible.
Ta,
wrathkeg
Ta,
wrathkeg
