Hi all,
I moved into a new house earlier this year and the old owner left a couple of his workshop tools behind. I don't think he'd used them for years, but one of the things he left is a Startrite bandsaw. Judging by the plug that's on it, the serial number A344 and the fact that there doesn't appear to be a model number at all I am guessing this is pretty old! I started it up and it runs enthusiastically, but the the blade wanders forwards and backwards a lot (5-6mm), and doesn't seem very tight.
I watched a couple of bandsaw setup videos and tried fiddling with the (initially pretty seized) knob to control the angle of the top wheel and adjusting the tension but nothing seemed to stop the blade oscillating to and fro, and even turning the wheels manually still produce the blade wander I'm seeing.
The other thing I found weird was that the top wheel and the bottom drive wheel were both marked 502 (presumably the same casting), but the top wheel has a rubber "tyre" and the bottom one doesn't. No idea if this is by design, but I certainly didn't seem to be able to get much tension into the blade, which would support the theory that the drive wheel has lost its rubber coating at some point.
The unit seems well made, and appears to have a cast iron cutting table, but I've never owned a bandsaw before and have no idea whether this means the unit is fundamentally ruined and I should haul it to the tip or try to fix it.
Any advice on whether this thing is tenable, and if so how on earth I'd be able to try to fix it, would be very much appreciated!
I stuck a few photos up here - happy to take some more if crucial bits were missed!
http://imgur.com/gallery/D6wdv
