Ok, I've reached something of an impass.
A single virtical beam with two boards attached to form a corner. My problem is trying to attach a board when the angle is greater that 90 degrees. Other than trying to shave off a couple of degrees from the angle of the beam, I'm not sure how to proceed with this one? A lot of the remaining design work relies on angles that arn't exactly easy to put together.
Call me ametuer...you'd be right!
Any ideas?
Cheers.
Any ideas?
Cheers.
