I am trying to match a pre-metric screw in an oldish English lock. Probably from the 1980's though it was designed in the 1960's or 1970's, and the factory probably used their existing tools.
It is almost M4 (later versions of this same model lock have an M4) but an M4 binds and will not go beyond around half a turn, so the thread is obviously wrong although the size is about right.
I thought it was UNC #6-32, which enters, and screws home tightly, so the thread must be about right, but is a very loose fit and wobbles (until it is screwed tight enough for the head to be tight)
So what can it be?
So what can it be?
