Hi all,
after turning off water outside (washing machine tap is broken as I discovered to my "surprise") I noticed the new washing machine was making quite a bit of noise when stopping filling. I didn't put two and two together until today and duly turned the tap outside down a little - this has solved the washing machine noise (and downstairs sink which has been annoying for ages actually)
Alas, now both upstairs bathroom taps are "hammering" quite badly when turned off - unless very slowly. I can feel which pipe it is (cold) but turning off the hot also makes it bang. I can only assume a couple of days of the washing machine banging have dislodged a pipe a bit? (It was pretty loud)
I'm not really in a position to go ripping floors up, so is there anything I can do? Thought about clipping the pipes together, but I've tried holding them and that doesn't do much.
Would one of these do the job on the cold pipe? ;
http://www.amazon.co.uk/Toilets-Pre..._cp_201_1?ie=UTF8&refRID=10CYP4WEVB9NM833E9M1
I note the guidance is to put as close to the "problem valve" as possible - sounds to me as if the problem is somewhere deep underneath the floor so would installing near taps make any difference?
Cheers for any help
Cheers for any help
