Afternoon,
I've a question about supplementary bonding in my bathroom. I'm replacing an old bathroom in a bungalow which was built 24 years ago. The floor is screeded and all water pipes in the place, including all c/h, are 15mm copper pipes with no plastic pipes except for the incoming mdpe mains water.
There will be copper pipe feeds to the loo, sink, bath, shower and rad.
There are three existing ceiling mounted downlights from one external light switch, an above ceiling inline extractor fan with a pull cord switch, and a combi boiler fed mixer shower i.e. no electric shower. The consumer unit is not RCD protected, just MCBs, although when the kitchen was done a few years ago the kitchen sockets were put on separate RCD fusebox by the electrician.
The plan is to replace the downlight/spotlight units with something similar (probably 240V GU10 LED spots) and in the same locations. The existing extractor will stay as is.
As no new electrical kit is being installed, do I need to have supplementary bonding connected?
Regards,
Kris.
Regards,
Kris.
