Searched through the forum but couldn't find anything similar to this.
We have a Baxi Solo 2 PF which developed an overheat fault yesterday. Haven't made any changes to the system recently, problem happens with both hot water and central heating.
Boiler runs for about 10-20 mins with boiler, fan, pilot & burner lights all on. Then boiler light goes out but the fan, pilot & burner lights are still on with the flame burning. The boiler and pipes make lots of noise until the overheat light comes on and the burner shuts off with the pump running continuously.
At first suspected the pump and turned this up from II to III but this has made no difference. Have ordered a new one anyway but am also wondering if this could be a PCB problem - if the pump over-run is not working then this could also explain what's going on. Have tried to check whether the pump is running once the boiler light goes out but this was difficult after running upstairs and trying to hear whether the pump is running while the pipes are popping and whooshing! Pump is running when the overheat light is lit however.
Can you help?
Can you help?
