Hi there, I'm a newby to DIYnot. I have a Candy Model: GO482/2-80 3100306509360386 washing machine giving problems. I've had it just on a year. Whatever program I select (apart from spin) the machine takes on water from both compartments and starts to heat up instantly to the highest temperature, (I've already boiled one load of washing!) it doesn't seem to do the intermittant wash & heat. Once the machine has taken on water it won't let me cancel the program to drain it, I can only get it to drain if I remove the clothes and bail out most of the water, it will then drain and indeed spin. I've done the usual, cleared the filter, checked the outlet pipe, blew down outlet hose and the pump seems ok, the impellor is turning ok.
Problem is that I live in Spain, but brought the machine over from the UK. So before I go down the road of calling out a Spanish engineer I would like to know if there is anything I can do myself.
Anyone out there got any ideas?
