(another) Ceiling Light Thread
2 Nov 2019
Quick ceiling light wiring question.
1st point to make is I have made the rookie error of dismantling everything before fitting as thought it would be a like for like. I have also reviewed a few other threads but I can’t seem to quite find an answer of how to wire into my particular light fitting (B & Q so assume it must be a fairly common standard?)
Existing Wiring;
2x Red
2x Black (of which one has a red sleeve on so assume it is the switched one)
2x Yellow and Green.
New Light Fitting:
3 Terminals only;
L – Manual states Red (or brown)
Earth – Green/Yellow
N – Blue and Black
I am thinking i will probably need to get an additional connector box to tidy things up possibly.
Any advice would be gratefully received.
Black with red sleeve ( switched live)to live terminal.
Black ( neutral ) to neutral terminal.
Earths to earth terminal.
The two reds do not connect to fitting,but go together in a third terminal block ,within the fittings housing.
Wow, thats awesome. Thank you for the quick reply. I had half guessed at that but wasn't quite brave enough to go for it.
Would you recommend wrapping the 2 reds (within their terminal block) with electrical tape or just in the blocks all good? Will be in a metal light fitting.
I would rather use a wago ,rather than a screw down terminal block ,but you can if you want.Electrical tape doesn't do much ,but it wouldn't do any harm.
