- Joined
- 27 Jan 2008
- Messages
- 25,344
- Reaction score
- 2,969
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
You have it seems worked out how to use these lamps. The only way as you seem to have worked out is to reflect the light off light surfaces and to have as wide as beam as you can.- Adjustable (so I can angle some at the walls to reflect the light)
- wide angle (for greater light dispersion)
As to dimming I like the Turkish idea of a 1/3 and 2/3 split so you have three levels of lighting with two switches.
I still feel the 2D and similar light fittings give a better spread but have to admit LED lamps have come on and the GU10 version does seem to be the most readily available version so being able to nip into local B&M Bargains and buy replacements off the shelf does seem to be an advantage even if only 2W and narrow beam.
That is what I have against dim-able although internet is no problem to quickly buy local replacement is a problem so would try not to use dimmers.
