Another Earth Question...
16 Jun 2005
Yorkshire
Just a quick one,,
Is there are simple way to check resistance for earth bonding etc?
Ie with a Multimeter? Ohm ratings?
Not really, as it is the overall resistance through the earthing system to earth that matters, not just the resistance across any bond. You'll only get an accurate reading using a proper earth loop resistance tester. Depending on what sort of earth you have, the range of acceptable values will be very different and you really need a meter that is using the main power supply to measure the resistance.
