so 6sqm (3m x 2m) of downstairs hallway, with front door as well as doors leading to: toilet, living room, kitchen, under stairs cupboard and then the opening to the stairs.
We used to have a small rad but it got removed due to an underground pipe leak. Since then that hallway has been cold.
So the initial idea is to put thermal boards down in the hallway and into the toilet (as its a concrete floor), put 5sqm of 150W UFH matting down, then screed on top prior to installing glue down LVT (or maybe tiles).
However there seems to be a lot of negative comments about electric UHF. It would be the only source of heating in that area but just needs to take the edge off the coldness.
To put a new rad back in would mean a different place from before and draw the pipes down from an upstairs feed, which is a ball ache as well as move some electrics.
We were also entertaining doing the same in the kitchen but for approx 9sqm. The current rad in the kitchen is too small but we could only replace it with a much taller one (not wider).
With the current cost of gas, maybe electric is the cheaper option now? We don't have the depth in the floor to go water-based UFH, nor the budget to channel into the existing floor.
Your thoughts please good people?
