Another Flat roof Insulation quiery
15 May 2009
Norfolk
Hi Guys,
I have two areas of flat roofing on an extension. One area is also a balcony for a 1st floor room.
The drawing build up on top of the ground floor joists is;
18mm board/126mm (Joists & Insulation)/firings up-to 50mm/18mm board/Sealoflex coating.
There is no mention of ventilation, and presumably this isn't a cold or a warm roof, Any design suggestions or advice out there that I could look into?
I have a BCO coming at the end of the week, and I'm hoping to have a bit of research done before he/she turns up.
Many thanks,
James
Do you have specific questions? Your post/description of the roof make-up is not clear. Are these built yet?
Tis why nobodys answred!
