- Joined
- 8 Feb 2021
- Messages
- 2
- Reaction score
- 0
- Country
Hi folks, I'd like to add some items from MK's Grid Plus system to my garage and I was wondering if you might be able to help me please?
The Garage
It's detached from the house and was built around 5 years ago (by the previous owners). I believe this was also when the electrics were installed. It's internal dimensions are roughly 5.7 x 5.4m, although there is a notch at the back making it an L shape. This means the internal area is around 28 square metres.
The Current Set Up
The current radial socket circuit goes from the consumer unit, to the five internal 2 gang sockets before heading outside to the external 2 gang socket. I believe this all made up of 2.5mm twin & earth cable?
The only thing left connected to any of the sockets is the garage door opener via a short run of flex and a 3 pin plug.
The New Setup
I'm planning on picking up a 12 gang plate + modules to support the following.
A couple of 1 gang sockets for low voltage car battery chargers. These will be mounted to boards between the joists above the cars, and only have the low voltage cable drop down (when needed). As the switches on these sockets will be out of reach, I'd like to control them with a switch on the wall.
I'd also like to add an extra switch for a new light to go above my workbench. Something like a 20w LED bulb.
I'd love to consolidate the garage door opener in to this as well, so I can turn it off when not in use.
At some stage I'll replace the fluorescents with LED panels. The drivers for which I'm hoping to connect to the existing wiring for the fluorescents. Each panel uses around half the power of the existing fluorescent bulbs and I'm planning on adding around 6 panels in total.
Drawing
Thank you for getting this far I've knocked up the drawing below, I'll not call it a diagram as it's far from being professional.
I think? This should be correct-ish, if not a little over the top? The big questions are...
The pink box at the top, can this be a simple junction box or does it need to be fused at that point? Or will the fuse modules I've added to the grid box be ok?
Is the way I've used the Terminal blocks (Wago connectors) inside the grid box ok?
I forgot to add this to the drawing but I'd like to add some form of isolator to the external 2 gang socket. This is luckily the last socket on the run and I'm hoping something like this fused switch mounted just before the cable heads outside, to the back of the socket, would be ok?
I also forgot to add an earth connection to the grid box itself.
Is this all fundamental a stupid idea?
I've tried to make things as clear as I can but if there's any more info folk need, please let me know.
Thank you
The Garage
The Current Set Up
- a Wylex NHRS204/40GWU" consumer unit (40A 30mA RCD & 2 MCB's ,6A and 16A).
- x2 70W fluorescent lights
- x2 LED external security flood lights
- a garage door opener
- x5 internal 2 gang sockets
- and an external 2 gang socket.
The New Setup
Drawing
Thank you
