Hi
found all kinds of helpful info here over the years, finally registered to ask something...
I need to replace a non functioning 12v transformer that used to feed an Ikea work lamp - single G4 halogen bulb, max specified 20W
the spec on the transformer says input 240V 50Hz, Output AC12V 1.66A
so AC output
- the old one was an all-in-one unit that plugged into a socket, connecting to the lamp flex via a DIN socket, though wiring a normal plug to a standalone unit is fine by me.
But what specs do I need to match in finding a replacement? In particular Amps
can I for example use one like this
http://www.tlc-direct.co.uk/Products/LTYT50.html
that outputs a max 11.5V, 4.3A or do I need to match the 1.66A exactly
(no intention to put a higher than 20W bulb in there)
so AC output
