In our house, the last 2ft of ceiling is sloping with the plasterboard fixed to the rafters. The rafters are 2x4, and there's only about 2-3" of glass fibre insulation. It's a cold spot and suffers from damp (and mould).
I already have a load of nominally 100mm (it's actually mostly about 90mm) tissue faced rigid foam insulation, and I was planning :
Any problems with that plan ?
That just leaves, how to fix the board.
"drylining" screws seem to stop at 100mm, while I reckon I'll need at least 125mm (90+13+enough to go into the rafters). The only other thing I've found that seems suitable are these "nail" :
https://www.twistfix.co.uk/drywall-insulation-fixing-stainless?cat=31
though I would have preferred a screw rather than a nail - though that's perhaps because I like things that give you a second chance when you don't quite get it right first time
Anything else I should be considering ?
- Pull off the existing boarding and remove the glass fibre.
- Fix one layer of insulation between the rafters (all foamed in)
- Fix another layer of insulation under the rafters
- A sheet of plastic as a vapour barrier.
- And standard plasterboard under that.
