I need to add 2 lights to my loft, one switch.
I had already looked at the wiring diagrams sticky and just went into the loft to see what things up there are like.
Messy is the answer.
The origional rubber wiring has been replaced, its still in place though.
None of the new wiring is clipped in place, its just all looped about loose. I assume it should be clipped to joists?
Anyhow, its the wiring im asking about.
There seems to be one supply from CU to a junction box. Black and red + earth.
From this junction box there are 5 single conductor red cables. One goes to each of the 5 upstairs lights.
There is also one black cable that goes to the nearest bulb holder. I assume this then goes off to each of the other bulb holders.
Each bulb holder has 3 single core conductor cables going to/from it. I assume ones the red, ones the black, and one is to each switch.
How is this system wired? I'd like to have a proper understanding of the circuit but dont want to lift all the insulation and trace every cable so i can work it out.
As for my new loft lights, can i go from the junction box i mentioned? The switch can happily be in line as its half way between the box and the new lights. Is it as simple as taking a 2+E from the box to the switch, then 2 2+E's from the switch, one to each new bulb holder?
Thanks.
Thanks.
