Another loose newel
8 Feb 2008
Bedfordshire
Need some exerience fixing loose newels so I might as well start on my own staircase. I've got a two part newel post that is loose where the circular tenon inserts into the lower section. Is there any point in drilling through and tapping a length of dowel through the tenon? Any advice much appreciated.
if its very loose and you can disconnect from the handrail easily pull appart clean up [rub down]the dowel and use cascamite or pu glue assuming the gap is less than 2mm
you may for safetys sake have to support the hand rail with a bit off 3x2"
Cheers for that. Am expecting to find a mess inside, as for some reason someone has banged about 8 nails into it! Are the adhesives you mentioned readily available?
