Lucky me, half way through an MFI installation of a negative head shower and they go bust. The originally plumber was having troubles, but now no-one seems to know what to do. Can anyone help?
- CWS level with the pump, in the loft
- HWS about 2 metre below the pump, in spare bedroom
- Shower about level with HWS, head usually about 1 metre above HWS, 1 metre below CWS/pump
- After problems with air, plumber fitted air valves (?) before and after the pump on both hot and cold. Worked for a week.
- Now, no hot water is pumped. Pump (salamander 1.5bar) selects negative head mode, inflow pipes run hot, but outflow pipes stay cold.
- Salamander say air valves un-necessary, and that the pump should be below the CWS...
But surely that's what a negative head pump is for? I don't want to put the pump in the spare room as it will wake the baby.
Any ideas before I spend even more on this wild goose chase? Hope this description is logical/makes sense?
