Another post about attic condensation
20 Jan 2024
I upgraded our insulation in our roof from 100mm to about 400mm - I have these plastic things at the eaves that I assumed were to allow airflow and put the insulation up to these.
After the first cold spell I noticed it was soaking up there - condensation everywhere so I pulled back the insulation from the eaves, left the loft hatch and the bedroom window open for a few days, and wiped down/vacuumed as much moisture as possible until it was clear.
Checked again today and it’s coming back. I wondered if the heat from the hot water tank below was maybe causing it but that’s also got about 400mm of insulation above it.
I then thought it could be that I’ve put too much insulation up there and that I’ll have to remove some.
And then I could add vents to the top of the roof.
Any ideas?
Any ideas?
Wow 2008 - you’ve been on here a while.
I see too much insulation isn’t on the list so at least I won’t have to do the horrible job of removing it.
