Another problem with my boiler
24 Sep 2008
Warwickshire
Hi all i have a baxi combi 80e boiler an the temp does what it wants. i turn the radiator temp dial down it goes up in temp i turn the dial up and the temp goes down. i no this from the light system on the pannel
1. Do you mean you turn the temp down/up at the wall thermostat or at the boiler thermostat?
2. Is this a new problem - i.e the system work OK previously?
3. Have you had anything changed - e.g a new thermostat?
Sounds as if somebody has changed the PCB and fitted the knob shaft 180° out of position!
Tony
it could not be thee temp stat thing could it i was tol there were 2 on the boiler the same and yes the boiler dial i am on about
Tony
I would have to agree with tony, this would be my first check if its completely backwards.
