Ok, so maybe two questions. lol
Bathroom window isn't sealing in the bottom hand corner, opposite side to the handle. The hinges are on top and bottom of the window. Presumably this window is top hinged, not side hinged?
Secondly, the bottom corner does have some movement in it and I can just about see the screws holding the hinge to the window are loose. I've managed to tighten the one furthest from the corner but I can't get to the other because of the window sill.
When changing the hinges, is it a case of unscrewing the hinges from the frame (but still attached to the window), then replacing them on the window, then screwing the whole thing back on to the frame?
Thanks very much in advance
