I am about to install a 10.8KW shower in place of a mixer unit. I have installed water supply from mains. Bought 10mm cable and have 10mm earth to bond to copper pipe just as it feeds shower. Electrical supply is from a new CU with 50A mcb that is only 8M from new shower. What size holes are needed for the floor joists that have the cable run through them? The cable rises from the floor and through a 300mm sq boxed section in the corner of the room - is this ok wrt permitted zones? After feeding a pull switch the cable will need to drop 500mm through a studded wall that is 4" wide including board and tiles. If I remove insulation from this area, can I just clip cable to the studding or does it need to be put into conduit?
Finally, is there a special tool for pulling tight the bond strap?
Many thanks from a virgin poster!
