- Joined
- 30 May 2004
- Messages
- 90
- Reaction score
- 0
- Country
I have read many of the shower postings but find I need to ask advice.
I have a gravity fed open-vented system in a flat & would like to install a shower. As there is only a ceiling lighting circuit in the bathroom, I was steering away from electric installations.
Cold water pressure is 2.2bar from a loft tank but the hot water head to the shower fitting is zero. I fitted a Croydex H2O venturi shower, hoping that the cold water pressure would improve the hot. The shower does not work, except on cold.
Alternatively, I have been looking at the Trevi Boost but am reluctant to invest more in a venturi system. Although they claim to work with negative head, £250 is an expensive way to find out.
Also, I have been looking at the Stuart Turner Showermate 1.2 Bar Single pump. This I would install at the hot tank, in the kitchen, & I would assume, requires its own 22mm pipe to the shower with a surrey flange to the tank. The hot tank is an Albion Superduty with 45 litre capacity, which may not be sufficient to pump.
I would appreciate any relevant comment on either option.
