After a recent ant infestation around my windows I decided it might be good idea to remove the window frame and see if there was any damage to the brickwork. It does look as if the ants had been tucking in to the fabric of the building. Having treated the infestation I am planning to repair the damage with mortar. However, a couple of other issues have arisen. On closer inspection I have realised that the slightly loose second brick up from the sill is actually a block of wood rather than a brick. Not sure why. I discovered something similar previously when one of the damaged bricks at the bottom corner of a door frame turned out to be a block of wood that had rotted away. Before I replace the block by the window I just wanted to check that there is no legitimate reason for this being wood rather than brick.
Also the wooden frames appear to have been deliberately prevented from coming into contact with the brickwork. As can be seen in the picture, there is quite a gap between the window frame and the brickwork, would there be anything to gain by filling this with sealant etc, or does the air gap help to preserve the wood. The windows are about 20 years old but there is no sign of rotting. Also although the sill frame was screwed into the brickwork plastic spacers had been used to create a gap of about 20mm between the wood and brick. Is there a technical reason for this, or was it just to create a particular sized aperture for the window opening?
