Are there any reasons why you cannot use ethylene glycol antifreeze in a central heating system.
The only reason I can think of is because its poison or toxic in some way.
That sounds like a good reason to me. Ethylene glycol is a nasty chemical, antifreeze for heating systems is propylene glycol which is much less toxic. It is used in high performance engines too as ethylene glycol does something to engines but I can't remember what. I think it's something to do with corrosion.
If you put etylene glycol in a heating system some day it will get drained out. To where? It shouldn't go down the sewer, definitely not into a septic tank.
i dont understand why you want to put anti freeze in a heating system, oh well , not for me to ask but to wonder why. I thought it had been asked before and it has, see this
