"Antiquing" and finishing a solid oak front door
7 Mar 2010
London
I have recently installed a solid oak cottage style internal door which I "distressed" by bashing gently with a steel ruler and sanding some of the sharp edges unevenly before finishing with two coats of Liberon dark oak coloured black bison wax. The effect was amazing. The buffed wax has a warm soft antiquey sheen being dark to black in areas I cut and chipped.
I shall shortly be taking delivery of a solid oak cottage style front door and want to repeat the effect. I'm supposing that a wax finish can't be used outside and so need some recommendations/advice on how to achieve the same look and type of finish.
I do not want to varnish. That leaves oil I think. Are door oils very flat or can they have a slight sheen? And what's the best way of darkening/staining the oak. Does anyone have any experience of Osmo oil woodstain. Or would I be better off with a spirit based stain followed by a clear oil such as Fiddes.
Any other ideas will be gratefully welcomed.
Many thanks
