- Joined
- 17 Jul 2009
- Messages
- 4
- Reaction score
- 0
- Country
Hi. This is my first post so hope someone will be able to help. Just got in to find that my Alpha 240e has a small leak.
Its at the diverter valve. Just behind where the front piece (with the 2 thin tubes) meets the assembly behind. Happens when hot water has been run. There are 2 small screws behind this front piece, which means that this front section can be removed. The leak is from the small screw at the bottom.
Does this mean that a new diverter needs fitting or is there a service kit which will fix the proble.
Advice appreciated
Phil
Advice appreciated
Phil
