Right here is problem!
I have an old Worcester Highflow 4.5 which I know I should replace but as I intend on moving house within 12 months then I would rather avoid the cost of replacement if I can.
I have a British Gas contract and recently the pilot light kept going out so eventually after a few visits BG said that the heat exchangers need replacing but they wouldn't do the work until I had a bypass value and magnaclean filter added to the system. So, I had a plumber fit both parts within a foot or two of the boiler that's in the garage.
BG then came back and replaced the heat exchanger on thursday. However, the pilot has kept going out and yesterday we had the smell of exhaust fumes in our kitchen which is next to the garage. Also the walls in the vicinity of the boiler began to soot up a few months ago and seem to be getting worse.
Transco came out yesterday and closed down the boiler saying it is not working correctly.
BG said when they replaced the heat exchanger that the bypass valve was fitted too close to the boiler as it needs to be at least 2 metres away.
Can anyone advise me on what I should do? Is the boiler on its last legs and I should just bite the bullet or do I try to get it repaired?
If I get the bypass valve fitted further away do you think this will resolve the situation or are BG just bull-sh1tting?
By the way the vertical flue to the boiler does not meet BG standards and is something like 600mm short. They have known this for years but are kind of ok with it.
Many thanks in advance.
Hoofer
Hoofer
