Any clues to the size of heating pump nuts
29 Dec 2009
Somerset
As it says really are the nuts on heating pumps a standard size? and if so what size is it ? and where is the best place to get a suitable spanner?
If you are referring to the nut that joins to the pump flange, then it is 52mm I think (on domestic size pumps). Screwfix sell a "pump nut spanner".
18 inch stillsons :idea: BUT get a cheapo pair . They will just open enough to do an immersion heater too :idea: and of course grip any round bar etc.
Thanks guys ,i tried the stilsons but they would go over the nut but not enough room to turn it but i have finally got the pump off using the old land rover method ;)
Stilson round a nut! plumbob would be turning in his grave! :LOL: OK OK we have all done it but make sure its a cheap pair.
AFAIK a pump spanner is only a few quid at a plumbers merchant.
About £16 :eek: ,i just used a cold chisel to get it going then did the rest by hand
