Hi
I have a Salamander RHP 75 fitted to my hot and cold water system. It's been fitted 10 years and pumps my hot and cold water to my basins, showers and baths.
It started making some strange noises, it was worse if you ran a bath upstairs and turned on the kitchen tap at same time. It got worse and worse until sometimes any hot tap turned on it groaned and stopped and started and Hardly any water came out.
I did find that if you turned on a pumped tank fed cold water tap on same mixer at the same time as the groaning hot water tap it stopped the groaning, then after 1 min you could turn off the cold tap and the pumped hot water was fine.
In the end I thought it's got to be the pump so I bought a new one, fitted it and turned a tap on and it's just the same?
What could be making the pump groan like mad?
It's a gravity fed system, the pump is just above the cylinder, there's a anti gravity loop fitted just before the pump from the hot water cylinder. It's a full house Salamander RHP 75 pump.
I have had three plumbers round and they all scratched their heads and said I'll get back to you!
Many thanks
Many thanks
