Any Ideal experts out there?
4 Aug 2005
Yorkshire
Isar circa 5 years old GC 47-348-15
Leak from domestic pipe at back of plastic dv.
No display (just red led on power switch)
I don't normally do Isar.
Is there an edge connector test I can do with my trusty meter to establish the no display is due to failed display pcb or can it be main pcb?
I presume to fix the domestic leak I have to remove bottom plate, remove plate heat ex, remove dv.
Any part numbers for o ring kits for replacement?
aaV was leaking, replaced that with generic one. There was a lot of water inside due to leak from aav and domestic so I wandering if all electronics shot. Any thoughts?
its probably both boards that are knackerd as the leak has come from the flue on the right hand side of the heat exhanger (primary) and drips down right on the connections of both boards
**** aint it :LOL:
as for the leak, my experiance is that your right its the o rings on the plated DHW he, I just have a pack of o rings and find that does the trick, and saves ordering them from ideal. Sorry I forget what the sizes are
if you have a leak coming from the combustion chamber, just check the condensate trap as they seem to get blocked with gritty stuff (i think its from the paint on the primary heat exchanger.
sorry not to be too compass mental with my reply it is sunday morning ;)
Thanks,
it's for a friend so if both pcb's are also invloved I'll probably recommend he gets Ideal to fix it I believe they do a £175 guranteed fix, would cost me more than that in bits and I wouldn't charge him much, so it would be me that suffers for the fact he bought a house with an Isar in it.
if you have no display on the front then the facia PCB is dead, but this board dont turn the boiler on so looks like the main PCB has gone as well
maybe for the best you get ideal out
For the best. I agree. Not the least for my knuckles. How anyone could consider producing a boiler where the sides don't come off baffles me.
I think they should put all Ideal designers on the road with a bunch of parts and see how they like it.
If I inherited a house with one (I'd surely not buy a house with one) I would cut the sides off it right away.
Like I had to do with my old xj6 (cut a hole in the boot floor to work on the inboard breaks).
If the AAV leaks on the icos/isar then it usually drips down and then it usually damages the connector on the rear of the display.
The part which most fails is the back to back pcb strip connector where it goes into the socket on the cable.
You have to buy a new cable and backplate for the display.
Tony
