Any ideas what this pipe could be?
16 Aug 2007
I dug up a small tree this morning.
When digging it up, I found this:
I only moved into the house a few months ago and I don't know what work the previous owner may have done.
For the time being I'm covering the hole with top soil then turfing it.
However, in spring next year I need to dig down about 1 metre and build a wall there to level out my lawn.
Anyone got any ideas what it might be? It's around 5 metres from the house itself, around 2 metres from the convervatory.
It's made from plastic, is around 8cm in diameter and runs to/away from the house.
Are there any pipe testing equipment I could buy or hire?
Is it perforated? Land drains have perforations, though I've no idea why one might be there!
Is it solid or pretty flexible? Is that soil really wet around it? Does the soil there smell of anything eg foul water?
its a ducting pipe, black is normally electric if you want to know what's in it take a pointed
sharp knife and cut a n shape in the top about 50mm then lift flap up.
unless of course its perforated.
Any garden electrics, or power to a shed/garage? Or hosepipe at the end of the garden?
I was thinking about this last night. Surely it must be a draining pipe (there will probably be a few running across the garden). It will probably run under the patio because it is block paved and will be porous. I'm going to inpect it this afternoon, clean it and look for perforations.
It's pretty flexible. The soil is wet, but I think that's down to the tree roots I pulled up.
No, none at all. There is only plants and trees in the garden.
It may be a piece of old discarded pipe.
I had found a pipe years ago about 2" dia, wondered what it was dug along following 3 foot later, a piece of old pipe,
LOL
I cut a flap in it and it just had dried soil in it. Must be a drainage pipe for the block paving patio.
