Any plasterers here ?
5 Jan 2009
I've started removing tiles for a new kitchen. The intention was to get a plasterer (when we can find one) to skim / re plaster the walls as we don't want to re tile. There are five walls and hundreds of these tiles.
In the pic of the utility I've removed the tiles and tile adhesive but as you can see the tiles have pulled some of the plasterboard away. I'm presuming this will happen in the kitchen itself which is quite large. Looking at the pic is it possible / feasible to plaster or skim over that damage or are we talking re boarding.
There will be new units above the old tile line around the whole kitchen so its simply a case of making good the tiled areas which are currently between the worktops and bottom of the upper units (18 inches) around most of the kitchen
Any thoughts ?
Skim it, small damaged areas can be replaced by screwing battens under the old p/b and screwing new (same thickness) board onto them, then skimming over.
Blup
Blup
Cheers. Would that area in the pic be suitable to be skimmed if I made good some of the dents and removed the flaking paper. I don't intend to skim it myself as lack the skill but would like to make it as easy as possible for someone else.
edit... a bit of googling would suggest it needs a coat of PVA, bonding plaster before a final skim.
