Hi all,
I'm going to have to build a 'box' in my bathroom about 10.5cm deep x 140cm wide x 70-80(ish)cm high to allow me to fit a new close-coupled loo without having a chuffin' great gap behind it (the soil pipe can't be moved back - see my initial thread [url]//www.diynot.com/forums/viewtopic.php?p=737750#737750[/url] for more info)
The box will be tiled with mosaic sheets (hence the 10.5cm depth - this is 4 misaics deep).
My initial plan was to make the box from a timber frame and MDF, but I've been scanning the forum to see if I'll need to treat the MDF first and have found no mention of the stuff ...is tiling on MDF a bad idea, and if so, what's the best material for me to make my little structure from?
I've used MDF for DIY preojects before and find it really easy to work with, but I've never used plasterboard so I'm a bit wary of that, especially as I've no idea if it's strong enough to use if cut to such a narrow (10cm) strip.
As it's gonna be a relatively small area, cost is not an issue ...especially as a local DIY store is closing down and had some good bargains for materials, and I'd rather spend the extra and get it right fist time.
One last thought. Whether I go for MFD or a different material, is it a case of "the thicker the better"? ... I was considering either 12mm or 18mm MDF.
The box will be fixed to a plasterboard wall.
Thanks in advance,
Mike
Thanks in advance,
Mike
