I can't buy an off-the shelf door lining the right size to fit an aperture in my old house... its really low and narrow (like 5ft x 2ft) but the wall is thick...
So, I am thinking of buying some of this http://www.diy.com/nav/build/timber...Smooth-Timber-L-2700-x-W-144-x-T-18mm-9275811 (ignore the picture, its the measurements that matter) or some of this http://www.diy.com/nav/build/timber...-PSE-Timber-L-3600-x-W-169-x-T-20-5mm-9275885 and just making a door lining to fit. The advantage with using something like this ^ for me is that the thinner the timber I use the wider the already narrow opening will be....
My only concern is that normal door lining timber is nearly twice as thick and I am guessing this is for a reason! Am I going to cause myself a problem using timber this thin to make a door lining? The door that will eventually be hung is nothing special - just a t&g cottage door, so no great weight and obviously its tiny as well.
What do you think?
What do you think?
