Any tricks for fancy/modern garden wall rendering?
29 Jan 2008
Liverpool
Hi all,
I want to build some garden walls and render them including the top (instead of having wall coping), like in the picture below.
Is there any trips or things I should be doing differently to achieve this finish? Is there simply corner render beads attached to the top of the wall, and off you go?
Andy
If you are going to use "standard angle beads" make sure that you use stainless ones...
