I'm renovating a room completely A to Z. Another room I did, the window wall when sorting out the plastering, I found the wooden window lintel had dry rot, and I replaced it with a concrete lintel.
Now I'm doing this second room, the wooden window lintel is fine. Is there any value in changing it now I have the opportunity?
Will it affect future plans, eg if I had a loft conversion done in the future? I read something in the past about joists above windows and how they are affected.
Also damaged / cracked floorboards, the 6x1 you can buy are about 5mm too small when replacing, what do people normally use when fixing these?
Many Thanks in advance!
