Hi All,
Got a three year old Baxi Instant 80 HE. Recently the hot water has not been as hot as it usually is and when i check the row of tempeature neons its only reaching 60 and going no higher. Is this normal? If I put pre-heat on to full it will then reach the full temp of 80. However if i then start running water it drops back down to 60
Is this normal or a fault?
Central heating is fine, there are no fault leds flashing and the pressure is correctly at 1.
PPS its not been serviced since it was put in
