Anyone got Kahrs (Engineered) wood flooring that squeaks?
23 May 2007
Manchester
Just had some Kahrs wooden flooring put down on the GF hallway (last few days).
Before the fitter arrived, I pulled up the chipboard floor and secured the wooden joists. Then I glued (pva) the joints on the new chipboard (18mm) and glued the boards to the joists. Screwed the whole lot down with 2.5in No. 10s.
Nothing moved no matter how hard I danced.
The fitter used screed to level the floor, and let it set overnight. Sanded it down the next day then added the underlay (foil backed - but I don’t know what kind - it is fairly heavy though if that means anything) and laid the floor.
There are gaps between all the wall edges, so the floor has not expanded too far, but the damn floor squeaks when trodden on (only in one place).
Is this normal for Kahrs flooring?
He said there would be some movement when stepped on but this would settle over time (?).
Not much I can do now it's all down, just wondered if the squeaking will go
, and if so, over what time frame.
Thanks.
Most floors, when very recently installed, are 'settling' down.
(And sometimes some part will creak every morning when the central heating has been off all night, wood is a product of nature and works)
So, give it few more day.
